Just found out that I will have to repair the insides of the rockers as well as the floor pans.
I will have the car shell on a a rotisserie when I do the work, which job should I do first?
I'm concerned mostly about removing too much metal at once.
Thanks,
Chris
https://www.classiczcars.com/topic/44715-floor-pans-or-rockers-first/
I'm going to assume that your outer rockers are in good shape. You'll want to weld in some braces across the door openings first. I'd cut out one floor at a time to gain access to the inner rockers. Repair the inner rocker and then install a floor. Repeat for the other side.
Chuck
