So right before I get on the highway my car had a strange vibration, I figured it was the road. As I got onto the highway it got worse, and something didn't feel right at all. At sixty miles an hour the vibration was terrible, and the faster I went the worse it got.
I pulled over (it was night and hard to see) but I took a peek underneath and nothing seemed amiss. No driveshaft hanging, no axles hanging, nothing weird. Checked the lug nuts, and visually inspected spacers (everything looked flush against the rotor). The vibration seems like it comes from the rear.
Any ideas to check guys?
https://www.classiczcars.com/topic/44728-suddenly-crazy-vibration/
Did you use a lug wrench to check nut tightness? And the second part of your sentence is unclear. What are these spacers that make things flush against the rotor?
Thanks for the replies guys, so here is the update.
So I made it home and this morning I jacked up the rear of the car, and spun each rear wheel only to hear a slight clunk noise. Jacked up the other side, and same clunk noise. I took a peek underneath and saw my propeller shaft spinning, but it was off center. So I'm thinking my propeller shaft (transmission to differential) has gone bad. A little research online shows that you can't replace the u-joints in the Z's driveshaft. I don't have a lift available to me at the moment (two cars stuck on our lifts to get work finished up).
So does anyone know about if there's anything else I should look out for? Or do I just need to order a new propeller shaft?
Ha ha, I went ahead and ordered a new aluminum one piece driveshaft. Might as well do it now then put in my RB and kill it later and with more damage. I don't know what else I should replace while I'm there though, shaft should be here Thursday
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
