Check lines and nozzle - especially the non functioning nozzle - again. My guess is an obstruction in the nozzle which has a smaller opening. Hook a section of like to it and try blowing through it. Aquarium clear hose works nicely as a replacement for the original fluid lines.
Dennis
https://www.classiczcars.com/topic/44780-wiper-fluid/#findComment-405354
To clear a windshield washer nozzle, unwind a stiff spring and use that wire to probe into the nozzle from the exit side. The small wire gauge of the spring should be able to go into the nozzle, and the stiffness will allow you to push it in. After you have made some attempts to clear the obstruction, do as Dennis suggests.
https://www.classiczcars.com/topic/44780-wiper-fluid/#findComment-405363
Did you check the "T" that splits the fluid line from the pump to the right and left nozzles? There's really not much to the system, so if the pump is pumping there must be blockage in either the line, the "T", or the nozzle. New line and a "T" are inexpensive. I'd start there since you feel that the nozzle is fully open. Have you disconnected the line to the side that doesn't work at the nozzle connection and checked to see how much fluid pumps out?
Dennis
https://www.classiczcars.com/topic/44780-wiper-fluid/#findComment-405407
  • Who's Online   1 Member, 0 Anonymous, 1,291 Guests (See full list)
