Dr. Wombat Posted November 3, 2012 Share #1 Posted November 3, 2012 This is my first Z.74 260Someone removed the electric FP. Wires are hanging there bareWith ignition on or car running there is no voltage.question; Should electric FP turn on with ignition(like radio)? Or does it run intermittent due to load condition?Thanks in advance-Dr. Link to comment https://www.classiczcars.com/topic/44853-another-stupid-fuel-pump-question/ Share on other sites More sharing options...
Dr. Wombat Posted November 3, 2012 Author Share #2 Posted November 3, 2012 Also all fuses are good, but I'm missing the cover, so no labels... Link to comment https://www.classiczcars.com/topic/44853-another-stupid-fuel-pump-question/#findComment-406023 Share on other sites More sharing options...
conedodger Posted November 4, 2012 Share #3 Posted November 4, 2012 Runs constantly when 12V applied. Link to comment https://www.classiczcars.com/topic/44853-another-stupid-fuel-pump-question/#findComment-406037 Share on other sites More sharing options...
Captain Obvious Posted November 4, 2012 Share #4 Posted November 4, 2012 The 74 is supposed to run the fuel pump when the engine RPM's are above 400 and the starter is not engaged. The electric pump shuts off if the engine isn't running.So, to answer your question... If your engine is running (assuming it's running faster than 400 RPM), you should be getting voltage at the fuel pump connector in the wheel well.See EF-6 and EF-7 for more detail. Link to comment https://www.classiczcars.com/topic/44853-another-stupid-fuel-pump-question/#findComment-406039 Share on other sites More sharing options...
