Hi,
I'm currently looking for a 240z with working A/C. My understanding is that A/C was a dealer installed option. My question is: Is it better to wait out for a 240z with working A/C, or find a clean Z and install an A/C?
Also, if if I find a clean Z without A/C, where can I locate an A/C kit, and how much would the installation cost?
Thanks,
Jacob
https://www.classiczcars.com/topic/44928-ac-for-240z/
Waiting to find a Z with working A/C could be a mixed blessing.....depending on how long, and how well, the A/C continues to work after you buy the car. Aftermarket A/C kits are available from a few sources, including MSA in Orange, CA. Kits run about $1,000 and plan on several hundred more to have one installed, depending on hourly labor rates.
I replaced my original A/C a couple years ago with a MSA kit and the total for kit & installation was about $1,600 - a little more than four times what the original A/C cost in 1972.
Good luck with the search!
Dennis
https://www.classiczcars.com/topic/44928-ac-for-240z/#findComment-406825
Hi Jacob. Do some searching on the site here Look in the forums) and you will find all of the answers to your questions. Bottom line: the old factory systems weren't all that effective unless it is a 260/280 system. A system like VintageAir (which replaces the heater assembly) works much better. I had the old-style system in my '73 back in '75 and it was marginal at best. In my current '73 I have a system from HotRodAir (since gone out of business, but very similar to VintageAir) and it works very well.
Cheers, Mike
https://www.classiczcars.com/topic/44928-ac-for-240z/#findComment-406826
Thank you all so much!
Dennis--I called MSA and unfortunately they are are sold out of the A/C kits. It is unknown when they will be selling A/C kits again.
Mike-- Is the Vintage Air System a universal kit or is it made specifically for the 240Z?
Arne-- I'm going to look for a clean Z, and then look into a modern A/C unit.
ZCurves-- Thanks for your advice. I will keep it in mind, but I feel installing a new unit is the route I'll most likely be taking.
Jarvo--Thanks for posting that info. Its really beneficial!
Edited by Jacob M
grammar
https://www.classiczcars.com/topic/44928-ac-for-240z/#findComment-406939
I live in Florida and I can do without A/C if it does not cause other temperature issues. Personally I don't feel that A/C and carburettors work very well in uunison. But to each his own. In addition to the heat issue here the power drain I could do without.
https://www.classiczcars.com/topic/44928-ac-for-240z/#findComment-406970
  • Who's Online   0 Members, 0 Anonymous, 1,266 Guests (See full list)
