z_ya Posted November 30, 2012 Share #1 Posted November 30, 2012 I have a 1978 280Z all stock the oil pressure gauge has suddenly stopped working, that or i simply have no oil pressure. I do know that there was an oil leak around the sending unit, someone decided to screw the sending unit still wired up further towards the block and now it reads nothing. Is it as simple as unscrewing the sending unit away from the block and it will start reading the pressure again, or am i gonna be getting a hold of that person to buy me a new unit? Link to comment https://www.classiczcars.com/topic/45050-oil-pressure-sending-unit/ Share on other sites More sharing options...
jwtaylor Posted November 30, 2012 Share #2 Posted November 30, 2012 I assume the tightening was done at the fitting that goes into the block, not the body of the sender. Screwing it in further should not have been a problem, unless the wire was twisted until it broke. Check the connection. Link to comment https://www.classiczcars.com/topic/45050-oil-pressure-sending-unit/#findComment-408103 Share on other sites More sharing options...
z_ya Posted November 30, 2012 Author Share #3 Posted November 30, 2012 It was the sender itself. Link to comment https://www.classiczcars.com/topic/45050-oil-pressure-sending-unit/#findComment-408112 Share on other sites More sharing options...
