Bit off topic, but putting the lower control arm on, do you just place the big bush in the crossmember and slide the spindle through? No washer between bush and crossmember?
Just seems to be tight, like it doesn't freely move up and down easily. I'm greasing all the nolathane with molygrease
ok i just read that VT v6 calipers are a direct bolt on to the 240K strut?? that would seem alot easier and i can get a pair of them for nothing quite easily! this true?! or sumitomos still better?
Any word if they are interchangeable?
