I've got all new seals so I can take pictures for you, just not sure which one you mean sorry. On the coupe there is the seals the run around the door itself and then the window seals that sit inside the chrome work at the top of the door opening. Is that the one you mean?
https://www.classiczcars.com/topic/45175-door-seals/#findComment-409384
