Here's what you should do:
1. Read through the EF section of the FSM.
2. Go through the troubleshooting guides.
3. Take notes through 1 & 2.
4. If you don't figure out why your pump has no power, tell us what you did and what you saw so we can help you.
https://www.classiczcars.com/topic/45181-nightmare/?page=2#findComment-409796
ok got it started. what i found out was PO had bypassed all of the relays i have a red wire from the ignition to the wire loom on the passenger side. now my question is my pump runs all the time the key is on will this burn the pump up? and now that think about it always has at least the short time i have owned it. looks to be a real nightmare to fix this right and makes me wonder what is or was not working right for the PO to have done this.
https://www.classiczcars.com/topic/45181-nightmare/?page=2#findComment-410113
