Where to find quarter window molding?
I believe the part numbers are 76840-E4100 and 76841-E4100. The Courtesy website says they have them in stock.
I assumed that they were no longer available from Nissan. Call or email David House at Courtesy Nissan. If they are still available he will be able to get them for you. dhouse@Kag-1.net
OK,...I received my quarter window moldings today, (Thanks David @ Courtesy). Now,...how do these attach to the window frame? The molding appears to have screw holes in them,...but there are no attachment screws or holes on the window frame itself.
The molding has a metal strip with the back covered in rubber. Does it glue on? any ideas?????
No one????? Any ideas????
Missed your post. Check out this thread:
http://www.classiczcars.com/forums/thread34108.html
Three screws and glue are necessary. Apparently early '71's and earlier z's didn't have this seal.
Also, the part numbers I listed earlier are for the lower quarter window seals. The correct part numbers are:
76837-N4500 WEATHERSTRIP-SIDE WINDOW RH
76838-N4500 WEATHERSTRIP-SIDE WINDOW LH
76840-E4100 RUBBER-SIDE WINDOW LOWER RH Banzai MW RU-03
76841-E4100 RUBBER-SIDE WINDOW LOWER LH Banzai MW RU-03
Dave
  • Who's Online   2 Members, 0 Anonymous, 1,435 Guests (See full list)
