Its a pressurized gas tube strut cartridge, KYB and Tokico are most commonly used. I use two big pipe wrenches; one on the top nut that is keyed like a bicycle crank nut, the other on the shock tube. After the threaded nut is off, hopefully the strut pulls out. Sometimes they get rusted into place. Don't think you'll run into that on this strut as it looks relatively modern (I'd guess 10 years old). When assembling, I put oil in the void between the gas tube insert and the strut body to prevent rust.
Once you get the gland nut off using the pipe wrench method your strut cartridge will either slide out or need some persuasion. Check out my thread below as I just went through this with my '72. I ended up buying a slide hammer and holding the strut tube in a vise and literally yanking the cartridge out with the slide hammer. Hopefully yours will just slide out! Keep us posted.
http://www.classiczcars.com/forums/thread47863.html
Got it with 2 large pipe wrenches and cheater bars over the ends. Turns out their was a fair amount of rust in the threads. The shock came right out. It was white and much narrower than the stut tube.
I have no idea what those abbreviations are stevej.
Thanks for the assistance everyone.
Abbreviations
Front Axle
Rear Axle
Factory Service Manual
Hey Hardway, Seen this post and thought of your effort straight away, but you already beat me to it. Your effort with the trees in post#17 is priceless;)
Bonus points for making do and Ingenuity:bulb:
Chas
  • Who's Online   1 Member, 0 Anonymous, 819 Guests (See full list)
