240k Style Posted January 8, 2013 Share #1 Posted January 8, 2013 Hey guys,Was thinking of using heaps of kill rust to stop surface rust and just rust in general to prevent it getting any worse. You guys use kill rust in a pressure pack for this or is there something else I should get. My poor old SSS pulsar (young compared to the cars in here) needs a touch up, and I thought I'd practice on her before I go near a project car Link to comment https://www.classiczcars.com/topic/45343-surface-rust/ Share on other sites More sharing options...
tez240k Posted January 9, 2013 Share #2 Posted January 9, 2013 I use chemsearch rust converter liquid that you wipe on with rag or a brush. Works really well! It's expensive but it does it's job Link to comment https://www.classiczcars.com/topic/45343-surface-rust/#findComment-411407 Share on other sites More sharing options...
EuroDat Posted January 9, 2013 Share #3 Posted January 9, 2013 What you need to do is stop the corrosion process. I use phosphoric acid rust converter. You can also use Tannic acid. Phosphoric acid comes in 1 or 4ltr containers. I have seen it in BBC and Bunnings hardware stores. Brush it on the rusty area and giverusty areas and give it time to dry.Dulux Rust Converters.pdf Link to comment https://www.classiczcars.com/topic/45343-surface-rust/#findComment-411413 Share on other sites More sharing options...
240k Style Posted January 10, 2013 Author Share #4 Posted January 10, 2013 Thanks for the ideas... Exactly I want to stop what's there, then go from there Link to comment https://www.classiczcars.com/topic/45343-surface-rust/#findComment-411480 Share on other sites More sharing options...
siteunseen Posted January 10, 2013 Share #5 Posted January 10, 2013 Here's what I have, it came with a car I just bought. http://semproducts.com/product-catalog/rust-and-corrosion/rust-mort/ Link to comment https://www.classiczcars.com/topic/45343-surface-rust/#findComment-411495 Share on other sites More sharing options...
