This 240Z is a lot peppier than my 280Z. Not as fast but quicker if that makes sense. Could that be the weight difference? Also what grade fuel should I run in the '72 240, highest octane or lower? Stock motor with the dome carburetors. Thanks for any responses. I promise not to flog everybody with questions right away. Sprinkle a few in over time.
https://www.classiczcars.com/topic/45358-2-completely-different-cars/
I've always ran at least 91 octane - but then I've always ran more initial advance in the timing. As I recall the original owners manual called for high test.. Nonetheless if your set up to run 87.. and you are not getting ping - run the cheap stuff.
FWIW,
Carl B.
Well wasn't the 240Z the quickest Z until much much later. The added weight was not made up for with HP fast enough. I use to have a chart that showed this. I thought the 240Z was the fastest Normally aspirated Z until the 1990 300ZX. However, I think all the turbo Z's were quicker than the original 240Z
What the manual recommends is equivalent to today's 87 octane.
Had to go check my Owners Manuals - you are correct for 1972 - 87 is for Reseach and Motor average. It was 91 RON in other countries.
The "original" Owners Manuals {69/70} did call for 91 Octane - but back then it was only Research Octane Number..
FWIW,
Carl B.
FWIW,
Carl B.
FWIW,
Carl B.
FWIW,
Carl B.
Precisely! ;)
  • Who's Online   0 Members, 0 Anonymous, 1,451 Guests (See full list)
