I have air condition systems in my 2 Z's. I don't want to run them so should the compressor turn or not? Keep them spinning so they want freeze up? Or take the belt off and let them rest until I want two use them. It gets hot down here so I might want them operational someday. Thanks.
Jcb's advice is spot on. Removing the belt on doesnt do much. Only the pulley and it external bearing turns, the compressor will only turn when the magnetic clutch is activated. Running the system once a month will keep the compressor and its shaft seal lubricated.
  • Who's Online   0 Members, 0 Anonymous, 1,266 Guests (See full list)
