I took them off to change the ujoints and diff seal. Now for some reason i cannot get the bolts on the diff side. I cant get a swivel socket i can barely get a wrench in there which is what i used to get them off. Anyone have a special tool or trick to make a 3hr per bolt job easier? I have flank drives also...wont work.
https://www.classiczcars.com/topic/45415-halfshaft-bolts-special-tool/
Shallow socket+ 18" of extensions at a slight angle. It's a small window of operation that will fit the socket and sometimes the socket will get jammed and will pull off the extension.
Rotate the halfshaft around to find the sweet spot. Hold the halfshaft in place with a prybar.
I use a Snap-On "wabble extension" with a short socket. I also clean & check the threads on the bolts when I have them out, then shoot a little Kroil on them. That allows me to screw them in with my fingers farther to start with.
FWIW,
Carl B.
  • Who's Online   0 Members, 0 Anonymous, 1,544 Guests (See full list)
