paranoid Posted February 17, 2013 Share #1 Posted February 17, 2013 hi guys,im from england and own a c130.unless you own a 220,260 or 280zx spares are hard to come by.do you guys fit poly bushes to the front track arms.i assume my suspension is the same as a c110.ideally would like to re-bush the whole front end,done the arb links.anyone got any links. ta Link to comment https://www.classiczcars.com/topic/45726-poly-bushes/ Share on other sites More sharing options...
Zed Head Posted February 17, 2013 Share #2 Posted February 17, 2013 Your post is hard to read and understand. Links to what? A fake plant with plastic leaves? Is a 220 like a 240 but with a 2.2 liter engine? c130? Arb links? ta?Might want to re-write it with a little more work put in to it. You might get lucky though. Good luck. Link to comment https://www.classiczcars.com/topic/45726-poly-bushes/#findComment-415238 Share on other sites More sharing options...
paranoid Posted February 17, 2013 Author Share #3 Posted February 17, 2013 yeah meant 240z.arb are anti roll bar links.poly bushes or neoprene.c130 laurel you didnt get them in the states.front track arms are what the stub axle and ball joint fit too?all looks fairly clear over here Link to comment https://www.classiczcars.com/topic/45726-poly-bushes/#findComment-415252 Share on other sites More sharing options...
