It could be a Roaster Tranny, if it has already been set up to use in a Z.
To put the Roadster 5spd. in a 240Z - you use the 240Z Bellhousing and change out the tail housing, main shaft an striking rod assy. Nissan Comp. used to sell a kit that contained all the necessary parts.
It is most likey a Type A 4 spd.
FWIW,
Carl B.
  • Who's Online   0 Members, 0 Anonymous, 1,534 Guests (See full list)
