First Time Solo Clutch Change - Lessons Learned
I just completed a solo clutch change for the first time and thought I'd document some of my lessons learned / tricks I picked up from my experience and various threads on this site:
Transmission Jack - 450 Lb. Capacity
- transmission jack really made the job easier
- I had to bend the strap mounting plates on the left side (far side in above pic) to clear my headers
- in my case, dropping the exhaust was a necessity to give me the required clearance to remove the transmission
- I pulled the fuel filter from its mount so that the fuel rubber fuel hose was not under stress
- I disconnected the upper radiator hose and removed the fan to allow the engine to rotate backwards
- disconnected the throttle rods also
- once I titled the engine and transmission down to remove the transmission, I put a small section of 2x4 between the head/valve cover and the firewall to limit the rotation
- I'm glad I did as I did the clutch change over a week or so, as I had to wait for the new clutch collar
- a few days later I went back to the garage and my floor jack that was supporting the engine had lowered and the engine was now resting on the 2x4
- my 240Z has five-speed from 280ZX installed
- when I removed clutch, I realized the pressure plate installed was a 240Z (240Z pressure plate on left, new 280ZX pressure plate on the right)
- new clutch pressure plate was much thinner, therefore required taller clutch collar
- ordered taller clutch collar from MSA
Motorsport! Clutch Collar, 75-83 Z/ZX Coupe Non Turbo, 84-86 ZX Turbo - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
- after reinstalling the transmission, I had trouble installing the clutch slave cylinder
- as I had changed the clutch collar with a taller unit, the clutch fork end now appeared to be slightly closer to the clutch slave cylinder
- what I should have done was to open the clutch slave cylinder bleed valve, to relieve some fluid/pressure to allow the clutch slave shaft to push further into the slave cylinder to allow for easier install
- what I did was force/lever the clutch slave cylinder into place
- after a number of simulated shifts in my garage (I wasn't making vroom vroom sounds, honest :)), the clutch slave cylinder failed internally (i.e. metallic pop, clang, spring noise) and the clutch pedal went soft
- the clutch slave cylinder was probably ten years old but the timing of the failure leads me to believe that forcing the clutch slave cylinder into place wasn't a good idea
- I ordered a new Beck-Arnley clutch slave cylinder and installed
- I swapped out the Shift Lever End Bushing and the Shifter Pin Bushing
- wow, what an improvement in shifter feel (a lot of "slop" removed)
Motorsport! Shift Lever End Bushing, 82-83 280ZX Non Turbo - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Motorsport! Shifter Pin Bushing, 82-83 280ZX Non Turbo - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
- I used long bolts with bolt head removed and slot cut into shaft
- screwed them finger tight into the top bolt holes in the head to line up transmission for install
- I first tried to install transmission with it in gear and it wouldn't go
- once I put transmission into neutral, install was easy and it slid right in
Anyway, I hope the above info helps.
Cheers,
Edited by Sean240Z
Good thread! I have few questions: i have 77 280z tranny and i have both small and big collars, when i bought the clutch i did not think any further and bought it for 240z, so should i use bigger collar? And does 240z slave cylinder work well with this setup?
Edited by Reverend
Koalia - If the pressure plate you received in your clutch kit is truly a 240Z pressure plate (i.e. the thicker / taller one on the left in the image above), you would use the shorter / smaller collar.
Wrt slave cylinders, mine is the non-adjustable slave cylinder and fork from a later 280ZX. I understand the the 240Z slave cylinder was adjustable and had a slightly different fork. Can someone confirm?
  • Who's Online   1 Member, 0 Anonymous, 1,300 Guests (See full list)
