I did a trade with a dude from CA... He sent me set of triple webbers and manifold. Only downside is that THIS IS NOT MATCHING TRIPLET :mad::mad:
Is it anyway possible to run with this setup or should i just resell these as matching pair + one..?? :cry:
All of them are 40mm.
Edit: dont mind about that booklet LOL it came with the package!
Edited by Reverend
https://www.classiczcars.com/topic/46011-major-screw-up/
Looks like a mash-up of the old and new style DCOE. This won't work (well) because of a few design changes, notably the different pitch and taper of the idle screws. I'm sure there are other minute differences that will make setting the carbs up properly a major headache.
Get a matching set.
https://www.classiczcars.com/topic/46011-major-screw-up/#findComment-417716
Some junkers near you @ low price: Three 40 Dcoe 18 26 45 for Spares or Repair | eBay
NOTE THE 18 NEEDS A THROTTLE SHAFT IT COULD BE TOAST.... I did this fix once. Not too bad to do. You may be able to scavenge the parts from the others.
New seals would be needed.
Edited by Blue
https://www.classiczcars.com/topic/46011-major-screw-up/#findComment-417770
I might be able to help you. I have several vintage 40DCOE-18s 'spare'.
One of them might be a close enough match to the two you have. Tell me what the individual numbers on the covers are ( the 'No' on the pad underneath the 'Tipo' line ) and I'll see if I've got one that's near.
https://www.classiczcars.com/topic/46011-major-screw-up/#findComment-417984
  • Who's Online   1 Member, 0 Anonymous, 1,514 Guests (See full list)
