Hi guys just wondering if anyone can point me in the right direction as to where I can get a replacement heater tap for under the dash as mine is pretty corroded etc. Is there a different model datsun which uses the same one? I looked at universal ones but most of them are a slightly different setup and need to be modified to work. I found the ones on Import Monster, these will be the last option i guess if cannot find something else as they work out to be roughly $130 delivered I think when I worked it out, might not be much to some people but would rather put it into other places on the build :)
Thanks in advance!
Matt.
https://www.classiczcars.com/topic/46064-heater-tap-help/
Has anyone ever managed to get parts from Nissan? I was told the all got sold off to places like About Time.
I have had plenty of success out of nissan in the states (mechanical parts), and ferntree gully nissan are also very helpful; they are actually Sponsors of Classic Skylines now aswell and give discounts on parts for Club members
https://www.classiczcars.com/topic/46064-heater-tap-help/#findComment-418428
Wow really! I've ben to FTG Nissan a couple of times as I live in Boronia and they are one of the best of JDM stuff. I've never had much luck with the C110 though. Maybe I'm not using the right codes. I believe they are all on microfiche? Do you know if there is anywhere to get a hold of them? :)
https://www.classiczcars.com/topic/46064-heater-tap-help/#findComment-418484
  • Who's Online   0 Members, 1 Anonymous, 1,442 Guests (See full list)
