My '72 Z has an L28 engine and I recently swapped out the 4-speed for a late ('81-'83 close ratio) 5-speed. Everything went back together and works fine. When adjusting the clutch recently I noticed I don't have a return spring connecting the slave cylinder to the clutch fork. My friend's '71 4-speed has a spring that is about 3" in length. I measured the distance my spring would have to be and it is about 5" and there are places on the slave cylinder and clutch fork for the spring to connect. I know some slave cylinders have this spring internal with the piston. Short of taking the slave cylinder apart, is there a way to tell if I need to go get a return spring? I don't want to wear out my clutch or throwout bearing prematurely. Thanks for your advice on this!
Gary
https://www.classiczcars.com/topic/46222-clutch-return-spring/
Frankly, I don't remember seeing a return spring on either my 73 or 74.
Come to think about it, I dont see the point of it except giving you excessive free play by overcoming the small internal spring in the slave cylinder and pushing the rod/piston all the way to the back of the slave cylinder.:ermm: Maybe Im missing something?
It would defeat the purpose of the internal spring which is there to take out the free play and adjust to clutch plate wear. To use a external spring you would need an adjustable rod and check it at regular intervals and adjust it for the clutch plate wear.
Chas
i was just looking through MSA z store and seen these slave cylinders. The 71/72 had adjustable rods. That would explain the spring on your system before you changed over to the new transmission.
Chas
Motorsport! Clutch Slave Cylinders - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
  • Who's Online   0 Members, 0 Anonymous, 160 Guests (See full list)
