i hope somene has a wire diagram for a 1971 zed.
Basically i used the stock fog lamp wire harness to install lights. Everything went fine.
My turn signals dont work.
Tested the switch-good
Tested the flasher on a bench-good
Checked continuity from the flasher to the fuse box-good
Fuse-good
Power to fuse-no power
Continuity from the fuse box to the wire harness plug under the hood-good
I tried applying 12v power to the circuit to energize it-no good
Im stumped. Maybe my diagnosing is flawed. Not sure. Im not an electrical engineer. Yet...
Edited by 71Nissan240Z
https://www.classiczcars.com/topic/46298-mystery-blinker-problem/
Did they work before you installed the lights?
Here's a link to a diagram - http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/240z/1971_240z.gif
