71Nissan240Z Posted April 17, 2013 Share #1 Posted April 17, 2013 (edited) i hope somene has a wire diagram for a 1971 zed.Basically i used the stock fog lamp wire harness to install lights. Everything went fine.My turn signals dont work.Tested the switch-goodTested the flasher on a bench-goodChecked continuity from the flasher to the fuse box-goodFuse-goodPower to fuse-no powerContinuity from the fuse box to the wire harness plug under the hood-goodI tried applying 12v power to the circuit to energize it-no goodIm stumped. Maybe my diagnosing is flawed. Not sure. Im not an electrical engineer. Yet... Edited April 17, 2013 by 71Nissan240Z Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/ Share on other sites More sharing options...
Zed Head Posted April 17, 2013 Share #2 Posted April 17, 2013 Basically i used the stock fog lamp wire harness to install lights. Everything went fine.My turn signals dont work.Did they work before you installed the lights?Here's a link to a diagram - http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/240z/1971_240z.gif Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-420837 Share on other sites More sharing options...
SteveJ Posted April 17, 2013 Share #3 Posted April 17, 2013 This should work for a 71: Hazard Switch ? Brake Light ? Turn Signal Circuit Analysis | Fiddling With Z Cars Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-420838 Share on other sites More sharing options...
71Nissan240Z Posted April 19, 2013 Author Share #4 Posted April 19, 2013 Hazard switch bad. Thanks for the wire diagram. Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-420976 Share on other sites More sharing options...
SteveJ Posted April 19, 2013 Share #5 Posted April 19, 2013 They can be cleaned out. Contact Dave Irwin or me about it if you need someone to do it for you. Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-420985 Share on other sites More sharing options...
71Nissan240Z Posted April 19, 2013 Author Share #6 Posted April 19, 2013 Cleaned the contacts reseated them and recessed the board a little further in to make up for the worn switch plus added a little grease. Alll is. Thanks guys Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-421006 Share on other sites More sharing options...
SteveJ Posted April 19, 2013 Share #7 Posted April 19, 2013 Cool, glad to hear that. Link to comment https://www.classiczcars.com/topic/46298-mystery-blinker-problem/#findComment-421010 Share on other sites More sharing options...
