240z fuel and brake line insulator sets and steering rack expansion reservoir
  • 3 weeks later...
Thought you might like to see a few of your parts on a car (Choke grommet,red check valve isolator and early hood bumpers). Very happy with the quality and fit of everything so far.
Dan
Glad that I could help you out, your car looks great.
Steve
Dan
70-71 console choke plate, a reproduction of the best one I could find, after a long search. Only a few minor dings on the plate but very nice.
I am also working on the square plug.
1969 240z maplight bezel in gray color.
I have been working on a few other rare items.
69 and early 70 plastic hood inspection clips, this is a sample of the smaller version from a 69 240z. I am working on testing the correct plastic type for this application, so they will not break once in use.
The early round type choke and hand throttle knobs.
more items are in the works.
Steve
[ATTACH=CONFIG]70856[/ATTACH]
Update: 69 and early 70 inspection clips. I tested the clips and after 200 open and close tests, the clips did not break. These are available in a clear amber color. The Black was only a test sample.
Steve
I also have the clips in clear, these are just a little more rigid than the amber clips.
As you can see on the picture that I tested these also and they did not break after 100 open and closes. I will be offering these as a set of 4 clips, 2 amber and 2 clear.
I will be doing more testing on the clips before I put them up for sale on website.
Steve
  • 1 month later...
  • 2 months later...
