Excellent. The arm would be much harder to source than the retainer clip.
I looked through my lock pics (get it?) and I don't have any pics of that clip, but I could take one if you can't.
And BTW - A P/N won't do you any good at a generic H/W store. Just take in your other clip to show as an example.
Cool. That clip isn't rocket science. That's why I was suggesting that a replacement clip (of some sort) would be a lot easier to source than a replacement arm.
As long as the clip you found holds the arm securely but still allows it to float on the cam and doesn't interfere with the linkage, it should be fine. Good idea to take a pic so others can see options.
  • 4 weeks later...
