Zachary Lawson Posted April 22, 2013 Share #1 Posted April 22, 2013 (edited) I would like to start off saying thanks for all the help from the previous posts. It has been really helpful, and I love you guys for it. My 78 is sluggish when accelerating when the motor is warm. I guess it isn't getting the right amount of fuel/air? I noticed today when the engine is cold, and the automatic idler kicks in. The car has much better response and power. I'm guessing this is because of the increase in fuel. It's mostly sluggish between low RPM's to medium RPM's when the engine is hot. It seems to help when I petal the gas before accelerating. Is my problem the fuel being too lean? Is my TPS not configured right or broken? ThanksNote: The car idles around 1200-1500 RPM's. It has a slight miss at those RPM's, but when you speed the motor up it doesn't. Edited April 22, 2013 by Zachary Lawson Link to comment https://www.classiczcars.com/topic/46344-when-the-engine-is-cold/ Share on other sites More sharing options...
Stanley Posted April 22, 2013 Share #2 Posted April 22, 2013 How hot is hot? 180? 200? 210? Don't know FI so I better not try to diagnose it. Hotter air to the intake means less power. On the other hand, my 240 makes more power when it's thoroughly warmed up: 3700 rpm = 78 mph (AT in high gear) when cool (but operating temp) in the morning; 3700 rpm=84 mph on a warm afternoon. Link to comment https://www.classiczcars.com/topic/46344-when-the-engine-is-cold/#findComment-421273 Share on other sites More sharing options...
Zachary Lawson Posted May 8, 2013 Author Share #3 Posted May 8, 2013 Sorry for the late reply, I've been gone on vacation. I figured out the problem. The pickup coil wires from age fell into. So I order a new pickup coil and it works great now. Thanks for the help. Link to comment https://www.classiczcars.com/topic/46344-when-the-engine-is-cold/#findComment-422867 Share on other sites More sharing options...
