I was checkin out the MSA website (Z Car Parts.com -- Motorsport Auto -- Home) for fire extinguisher stuff, and I saw a mention of something called a "Battery Frame Insulator." It's supposed to go between the frame and the firewall, where the frame bolts to the firewall. Apparently, its job is to eliminate the frame from rubbing or scratching the firewall.
Would this be a useful part? Would you pay $20 for a rubber spacer? It's just a chunk pf rubber with a slit for the battery frame handle and a slot for the bolt, you'd also need a longer bolt. Couldn't you just substitute a rubber spacer you make yourself?
Motorsport! Battery Frame Insulator, 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
https://www.classiczcars.com/topic/46379-battery-frame-insulator/
You could buy the same item from Banzai Motorworks for $13,and, for another couple bucks, get the correct machine screw.
I guess you have to figure out if it is part of the vision you have for your car.
I put one on my car because it was an original part for a factory correct restoration.
Blue, I have always assumed that the purpose of this rubber insulator was to cushion the battery frame/firewall surfaces, and prevent damage
to these surfaces. The long J-Rod that secures the front side of the battery frame to the battery tray doesn't have any isolators, so, I never
thought of this rubber insulator as something meant to electrically insolate the battery frame from the body.
The bolt sold at Banzai has a large flat washer to help hold the insulator firmly in place, and this rubber insulator is partially split so as to fit over,
and protect, both sides of the battery frame mounting tab.
Let me know what I am missing as I don't mean to mis-interpret what you meant.
Dan
Edited by AZ-240z
Blue, you could put all I know about electrics on the head of a pin. Most of the time, my responses to these threads are more a question looking for
clarity. The stock positive battery cable clamp had a plastic cover protecting this cable terminal in the event the battery came loose and the positive post
came in contact with the inner fender.
Dan
  • Who's Online   2 Members, 0 Anonymous, 1,428 Guests (See full list)
