Anyone else thinking of going down this path? Seems an easy way to have a fairly new bullet proof LSD
Tranny & Rear Diff Parts
It's the ones from the Hybridz forums and Kev from JNC Hakosuka fame has them as well
I'm thinking easy way to get a good LSD in the gearing i want (3.9)
https://www.classiczcars.com/topic/46407-r180-sti-clutch-lsd-side-axles-swap/
Done some more research, using a all the pictures I've seen indicate long nose set up.
Need the change the input shafts (25 to 27 spline), we in Australia are lucky, some NA S13s, U13 AWD Bluebirds, use 27 spline 4 bolt CV shafts that fit perfectly (apparently). Otherwise you need to change dust caps etc etc.
I'll do some more research, could turn out cheap being as we are in Australia.
These axles are made to fit the Subaru diff splines using the original datsun half shafts!!!!
