ninjazombiemaster Posted May 8, 2013 Share #1 Posted May 8, 2013 After a year of jolly good fun, I'm pretty sure I've burned out my clutch. It takes incredible amounts of engine power to translate into even the smallest amount of power to the wheels. The engine idles and revs up fine - but when put into gear and ready to go its a slow crawl forward. I've had the car since July, so nearly a year, and really don't know what kind of shape the clutch was in when I got it but needless burnouts at every stoplight do indeed lead to premature wear. I am considering this kit: Heavy Duty Clutch Kit 1973 Nissan 240Z Base 2.4L l6I'll have to make one last pathetic drive to the shop (hoping it makes it) where my DD will stay for days, until the part arrives. As far as I'm aware they can't be found locally here in Salt Lake City. On a more positive not, that explains the recent loss of power and gas mileage! Here's to another year of peel-outs before inevitable clutch failure..! Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/ Share on other sites More sharing options...
Darrel Posted May 8, 2013 Share #2 Posted May 8, 2013 exidy Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-422851 Share on other sites More sharing options...
steve91tt Posted May 8, 2013 Share #3 Posted May 8, 2013 I run a BRUTE POWER / PERFECTION CLUTCH 92016B clutch in both my cars. Cheap and indestructible. I've got +6000 track miles on my Rebello powered track car and it's still going strong. I paid less than $80 for the kit which includes a bearing, bushing, collar and clutch. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-422857 Share on other sites More sharing options...
Zed Head Posted May 8, 2013 Share #4 Posted May 8, 2013 A slipping clutch generates lots of heat, enough to destroy the flywheel. Crawling to the shop while it slips might not be a good idea. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-422868 Share on other sites More sharing options...
tlorber Posted May 8, 2013 Share #5 Posted May 8, 2013 Just to be clear, are you hearing the engine rev when the clutch is supposed to be engaged? Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-422881 Share on other sites More sharing options...
ninjazombiemaster Posted May 9, 2013 Author Share #6 Posted May 9, 2013 You're right - it doesn't makes sense to risk destroying the flywheel to save $50 on a tow. That being said, I'd also rather not spend $50 on a tow. I ended up getting that kit I linked too, but I found a better price on it. $100 even with free shipping. I'm expecting it in a day or two. Long term, I'd like to upgrade to a nice one, but this is really just a matter of getting my daily driver back on the road as soon as (and as inexpensively) as possible.The engine revs when the clutch is supposed to be engaged like normal. Just almost none of that power gets to the wheels. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-422919 Share on other sites More sharing options...
ninjazombiemaster Posted May 11, 2013 Author Share #7 Posted May 11, 2013 3 hours in the shop and shes back on the road. The wearing was on the pressure plate side of the disk, so the flywheel was actually in great shape. Forgive that some of the photos are sideways. I uploaded them directly from my phone and it refused to let me rotate them. Ready for a lift. The new disk. The old, very worn plate and disk. The flywheel at the machine shop, getting a resurface for good measure. Nearly back together.. I still need to adjust the clutch. It still seems to slip at higher RPMs - but it definitely grabs much better. I need to resolve that before I damage this one prematurely. I've never done it before, so any tips are appreciated. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423109 Share on other sites More sharing options...
LeonV Posted May 11, 2013 Share #8 Posted May 11, 2013 The procedure is in the FSM. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423137 Share on other sites More sharing options...
ninjazombiemaster Posted May 11, 2013 Author Share #9 Posted May 11, 2013 Ok. I'll check it out. It actually seems to have mostly self-resolved. But its always good to check anyway, since if the clutch doesn't disengage enough, its just needlessly wearing it down. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423150 Share on other sites More sharing options...
Darrel Posted May 11, 2013 Share #10 Posted May 11, 2013 check the holes where the pins holds things together at the pedal and clutch master, make sure there isn't any slop. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423151 Share on other sites More sharing options...
ninjazombiemaster Posted May 13, 2013 Author Share #11 Posted May 13, 2013 The FSM only mentions moving the lock nut on the Master push rod to about 8.Something inches. Is that really all there is to it? Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423254 Share on other sites More sharing options...
Captain_Zeros Posted May 13, 2013 Share #12 Posted May 13, 2013 Yep, that's your only adjust point unless somebody has gone and replaced the slave cylinder actuator rod with an adjustable one. Just adjust the linkage where the master attaches to the pedal until the clutch bite point is to your liking & the clutch fully engages and fully disengages. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/#findComment-423273 Share on other sites More sharing options...
