ninjazombiemaster Posted May 13, 2013 Author Share #13 Posted May 13, 2013 Yep, that's your only adjust point unless somebody has gone and replaced the slave cylinder actuator rod with an adjustable one. Sounds easy enough. I just had a hard time believing it was that simple. Hopefully what feels like slippage is just the clutch not fully engaging, and not a sign of a poor quality plate. I could afford the kit and a few hours in the shop - but I can't afford to redo it. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/?page=2#findComment-423274 Share on other sites More sharing options...
ninjazombiemaster Posted May 13, 2013 Author Share #14 Posted May 13, 2013 Happy to say that moving the pedal stopper back appears to have done the trick. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/?page=2#findComment-423278 Share on other sites More sharing options...
Captain_Zeros Posted May 13, 2013 Share #15 Posted May 13, 2013 If you have problems with the clutch not engaging with new parts installed, give this a read too: Nissan Throwout Bearing Collar Specs Comparison MeasurementsThere are about a zillion combos of throwout bearing collars and pressure plates. As long as the whole stack adds up the right thickness everything will be fine, but if you have a tall pressure plate and a tall throwing bearing carrier, then the distance will be wrong and it'll rub on the pressure plate and prevent the clutch from fully engaging. If you have a short pressure plate and a short throwout carrier then it won't reach far enough and it'll never disengage properly. I've heard it can be a real headache if you mix and match different years or different models of transmission and don't keep the matching parts together.Hopefully you don't have that issue, but it's something to be aware of if you keep having problems. Link to comment https://www.classiczcars.com/topic/46490-there-goes-the-clutch/?page=2#findComment-423279 Share on other sites More sharing options...
