"For over 40 years, Rogers Corporation has been the leader in the design and production of liquid level floats where resistance to gasoline, oil, and other hydrocarbons is essential. The key is in our NITROPHYL® NBR (Buna-N) Technology."
Rogers Corporation NITROPHYL-Floats
https://www.classiczcars.com/topic/46789-su-floats/?page=2#findComment-425869
Haven't found anyone that sells Nitrophyl resin raw components to "cast your own"...
Nitrophyl is a trade name from Rogers corporation? The basic rubber is a closed cell NBR rubber (Technical name: Acrylonitrile Butadiene). It also goes under trade names as Nitrile & Buna-N, Nipol & Europrene.
Rogers corp does not sell resins. We (where I work) have used them in Gent Belgium, but they require €1200 tooling costs and a minimum order of 250 pieces. That was a special rubber bellow for a high speed shear mixer.
The vulcanising process for NBR if not easy for a hobby guru to try. Probably why no one making them...
Refab from another larger float could be a possability though.
Chas
https://www.classiczcars.com/topic/46789-su-floats/?page=2#findComment-425909
Now that I know some more trade names for the stuff... Thanks Chas!
how about this for stock?
McMaster-Carr
"This economical grade of Buna-N offers good resistance to oils and solvents but is not as weather resistant as other rubbers. Also known as nitrile, acrylonitrile butadiene, and NBR."
Edited by zKars
https://www.classiczcars.com/topic/46789-su-floats/?page=2#findComment-425910
That stuff from McMaster would be about as hard as a shoe heel and difficult to machine, but you guys are missing the most important tricky part... It's solid and it won't float.
The tricky part to the Nitrophyl is that it's a FOAMED Buna-N, not solid.
According to Rogers, you can machine and glue Nitrophyl sections together to make a float, but it's not as simple as taking a solid hunk of typical Buna-n (like what McMaster offers) and trying to hog out a float.
https://www.classiczcars.com/topic/46789-su-floats/?page=2#findComment-425935
  • Who's Online   1 Member, 0 Anonymous, 1,414 Guests (See full list)
