Hi, I've reached the carb set up stage of my restoration now. I've got a colour tune and a uni-syn so I started with trying to balance air flow.
I set the uni-syn so the front carb bought the little float up to around the centre mark of the tube and then tried the rear carb and it's not even registering on the uni-syn at all.
I would screw in the throttle screw but at the moment the rpm is really high even though I've got both individual throttle screws backed out all the way, and the screw on the main throttle linkage is also backed off all the way.
I read somewhere to check for vacuum leaks with carb cleaner so I will try that tomorrow but I was wondering if someone could give me some advice and things to check.
I've never worked on carbs before so my knowledge is very limited but I'm keen to learn.
Many thanks.
https://www.classiczcars.com/topic/47022-carb-trouble/
One way to be sure is remove that carb and see if the butterfly is open at all. It wouldn't take much air to slip by. You could use a feeler gauge or probably could see visually if its open at all. If it is , ten your linkage is probably at fault.
It's only four nuts!!
https://www.classiczcars.com/topic/47022-carb-trouble/#findComment-428149
You checked the idle adjusting screws, first step, right? They're on each carb body right where the linkage between the carbs meets the carbs. Move them both all the way up or all the way down, and then screw each the same number of turns until they're in the middle where the idle is about right. Then set the balance, mix, fast balance, readjust the idle screws, and repeat.
In case I left something out, the FSM tells it best.
https://www.classiczcars.com/topic/47022-carb-trouble/#findComment-428275
