I had a thought...look out! What about the old hot start problem? Would the OE hardline hold heat too much? Just asking because you guys live in completely different heat zones. Down here in the Deep South, mine is cool to the touch while flowing fuel and heats up very little on shut down. i know I won't win this but just thinking out loud. Cheers!!
Edited by siteunseen
Siteunseen
This is actually a common question from people. If your fuel system is completely sealed and working correctly - the check ball works no leaks etc - then there should be no hot start issues none zero. Mine has an issue but that's because the check ball in the pump is bad - or stuck - and lets the fuel leak out a bit, leads to some leaning when I restart after a drive. I usually just let the fuel pump run until I stop hearing air enter the fuel tank - it sounds like bubbles.
Blue,
Is it necessary to make the ends on the fuel rail? Couldn't one just attach a fuel line. I can see the use(s) of it just wondering.
Thanks
Jan
  • Who's Online   2 Members, 0 Anonymous, 1,512 Guests (See full list)
