240260280z Posted August 1, 2013 Share #1 Posted August 1, 2013 The throttle arm connected to the main shaft was wallowed causing rotational slop and delayed throttle valve actuation. I brazed the hole in the arm then drilled out and filed to fit the main shaft better. Link to comment https://www.classiczcars.com/topic/47113-brazed-and-re-filed-weber-throttle-arm/ Share on other sites More sharing options...
