Hello All,
Well after searching the site I still cant find an answer to my question so I am going to post it. I have a 72 Type B 4-speed. I have to replace the 2 side bushings and the 1 bottom bushing. The Fische I have doesnt show the bent shaft shifter at all. Does anybody know if the part number for the bottom bushing is 32861-24900 or 32861-N4200 ? Or are they the same? Any help is greatly appreciated!!
Thank You, Jeff
https://www.classiczcars.com/topic/47275-72-240z-type-b-shifter-bushings/
the bottom nylon bushings are all the same.
There is a thread about a door hinge bushing that can be used in place of the plastic stockers.
Maybe its on Blue's tech tips... Yup, http://atlanticz.ca/zclub/techtips/shifterbushing/index.html
After going through the effort of making my own out of brass, I saw some on eBay ( made of brass as well). They were pricier than the plastic ones, but I'm sure you'll never replace them again.
The original plastic ones in my '71 Z lasted 40 years. If the replacement set of plastic ones from Nissan last as long, I'm sure I'll never replace them again, either LOL
Dennis
My plastic OEM bushings lasted nowhere near 40 years, they shattered and fell into the transmission to get ground into dust many moons ago.
I went with the chrysler door hinge bronze bushings and it was super easy to install and my shift feel is crisp and wonderful. I see no reason to use plastic bushings when such a cheap and easy bronze solution is available. The parts were hanging on the peg at the local parts shop!
Around five bucks, just slot in the ones that fit, the rest got thrown in my parts bin.
Edited by Captain_Zeros
[ATTACH=CONFIG]65537[/ATTACH]
Did the same, very crisp, no slop.
  • Who's Online   0 Members, 0 Anonymous, 902 Guests (See full list)
