4 hours ago, jalexquijano said:
You have not advised me on the level of the rear carb. Do i still need to bend the tang more?
Read this and you will be good. http://www.classiczcars.com/forums/topic/59745-definitive-70-71-240z-su-fuel-level-thread/
Edited by 240260280
Another thing I thought of I don't remember mentioned is a fire extinguisher. Jalex you need a fire extinguisher.  The metel tipped Kidde fits perfect behind the passengers seat in that tool box. You need to move the spare tire tools behind the driver's seat tool compartment.
27 minutes ago, siteunseen said:
He needs a timing light that shows rpm. May get a loaner from a chain store?
There's a nice one on Amazon for less than $80.  I may have to look into getting one of those, myself.  My 45 year old non-digital dwell tachometer is probably a bit out of calibration at this point.  Any brand recommendations?
Dennis
Dennis
Can't remember the name but it looks like an old flip phone. $100 red and blue backlight screen. amazon.com
https://www.amazon.com/INNOVA-5568-Pro-Timing-Light-Tool/dp/B000EVU8J8
It does it all. I like the dial back setting. I put it on 34 degrees rev it until 2,500 rpm and goes to zero.
took the car for a ride yesterday and had to dial both fuel mixture knobs to 4 turns clockwise. 3 or 3.5 turns simply dont work. Could this be attributable to the fact that my engine is not stock and has been modified to 2.6Liters with a Schneider 274F camshaft and pertronix ignitor module and coil? I would really like to set it to 2.5 or 2.75 turns clockwise but it becomes to lean and lacks power.
I will test the car today without the airbox fastened to the carbs to ease the adjustments if necessary.
Edited by jalexquijano
so 3.5 to 4 turns will be okay? in the past the former airtex 8012s fuel i had installed measured 4.2 psi and i could dial it at 2.75 to 3 turns clockwise. Maybe in the end the car does not need the 4.2 psi and will run okay with 3 psi but i will need to open the carbs more.
You've been trying to adjust a modified engine to stock factory settings.  That can be like trying to fit a size 12 foot into a size 10 shoe.  The process of tuning the engine/carbs results in adjustments to settings to a point where it runs best.  Sounds like you're finally just about there.  Button that baby up and head out on the highway!
Dennis
