Also, if you think your car is running lean on acceleration, try putting an 80wt oil (thick) in the carb dampers to see how enriching the transition works.
If you think your car is running rich on acceleration, try putting ATF (thin) in the carb dampers.
30wt oil is the recommended oil for your climate.
Edited by 240260280
It is probably a gearing issue overall. Depending on which 5 speed you have, your gearing could be a little high, which will make your launch a little slower. If you go to a lower gearing in the rear end then your cruising rpm's at 100mph is going to be much higher. There's no free lunch here. After all, you are only working with 150 or so HP if you're lucky. It's not going to launch like a modern EFI car that makes 200 or more HP and could have as many a 8 tranny gears. For us in the states, law enforcement tends to lower the speed range we build for, so we don't have to worry so much about higher rpm's. We can run lower rear end gearing and not have to worry about high speed rpm so much
What does this mean? Out here in the western states we have hundreds of miles of interstate with 80 MPH speed limits.
IMO the slow response in first gear is the nature of the beast and is likely made a bit worse with the upgraded camshaft. I'm assuming that around 3000 RPMs it starts pulling strong. A lighter flywheel could help it a bit in the lower RPMs but a heavier flywheel is better for stop and go traffic.
This is true, and in some places like Montana they have effectively no speed limit. However, if you look at the member map, most of the member cars reside in areas that have substantially lower speed limits. Jalex  (who is in Central America) is evidently routinely running a 100 mph in his car evidently for extended periods of time. I suspect if 100 is the norm, then 120 is not out of the question. I don't know about Utah but much above 80mph where I live is going to get you tagged (our highest speed limit is 70 mph). Even in Texas they have very high speed limits (80 mph on secondary roads) but many times they will ticket you for 5 mph over (got one about 2 years ago), where as they tend to give 10 mph here. Big difference in rpm from 85 mph to 120 mph...
Another point is many people set their cars up for acceleration, light to light so to speak. Most are not set up for high speed cruising. That being said I have run a z for hours above 5k rpms with a four speed with no obvious ill effects
