JacktheRiffer Posted September 5, 2013 Share #1 Posted September 5, 2013 Can road angle cause the alignment to feel off? Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/ Share on other sites More sharing options...
zKars Posted September 5, 2013 Share #2 Posted September 5, 2013 You are correct. That is an odd alignment question. I think we are going to need more details before anyone will be able to give you a usable answer. Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/#findComment-431116 Share on other sites More sharing options...
JacktheRiffer Posted September 5, 2013 Author Share #3 Posted September 5, 2013 When im going down a road (mostly highway) ive noticed that the roads tend to angle abit (to drain water i guess?) But ive noticed when i am on these angled sections i have to hold the wheel abit to the left in order to go straight when the road angles down to the right and vice versa if it angles the other way. Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/#findComment-431119 Share on other sites More sharing options...
John Coffey Posted September 5, 2013 Share #4 Posted September 5, 2013 Normal. Alignment specs are for flat roads. Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/#findComment-431123 Share on other sites More sharing options...
JacktheRiffer Posted September 5, 2013 Author Share #5 Posted September 5, 2013 Thanks was nervous my car was messed up. Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/#findComment-431159 Share on other sites More sharing options...
Jeff G 78 Posted September 5, 2013 Share #6 Posted September 5, 2013 Yes, it's fairly normal and will vary from vehicle to vehicle and tire to tire. Some states have higher crowns on their roads. Florida has the biggest crowns since everything is flat and they get heavy rains. Tires are designed to offset this. They have a built-in conicity (cone shape) to help give the vehicle a slight left bias. Some cars also have different caster side to side. More caster on the right front will help offset road crown pull.It's also possible that your tires aren't inflated evenly. All it takes is about 5psi low on one tire and you will get a slight pull. Link to comment https://www.classiczcars.com/topic/47347-odd-alignment-question/#findComment-431169 Share on other sites More sharing options...
