Good morning everyone,
I currently own a 1975 280z and have the opportunity to get a 240z shell. I've read that they both use the same chassis and the difference from the exterior are the front and rear turn signals. I would like to convert my 280z to a 240z and I was wondering if all the interior and drive train of my Z will retrofit in the 240z.
https://www.classiczcars.com/topic/47396-280z-face-lift/
If you are just talking about face lifting the 280Z, you will come into some problems converting it.
The rear quarters dont have the recesses for the bumpers. The tail light panel will need modifying to fit the 240Z tail lights. The 240Z front centre valence section wont fit because the cross member in front of the radiator is too low. This can be fixed by fitting a air-dam with the 240Z turn signals.
The reason I know this: Been there, done that. Or should I say; doing that. http://www.classiczcars.com/forums/body-paint-s30/48611-fitting-240z-bumpers-valences-280z.html
Chas
https://www.classiczcars.com/topic/47396-280z-face-lift/#findComment-431591
Now I understand. When you said "280Z face lift" and "convert my 280Z to a 240Z" I thought you wanted to make your 280Z look like a 240Z.
It really depends on how handy you are and how much a shell the 240Z is. The list is LONG and you will run into the smallest things. Things like the brake and fuel lines from front to back are totally different. Dash and fuel tank are different. You can overcome this but its a lot of work.
Chas
https://www.classiczcars.com/topic/47396-280z-face-lift/#findComment-431618
