Anyone else feel like the Nissan rear seals aren't up to snuff? My 73 just developed a pretty good rear seal leak. It has a new (blue) Nissan rear seal (2000 miles). Which seal works best for you? I'm going to go back with Felpro. I was going to replace the tranny with a 5 speed anyway, but it still makes no sense why a seal with that low mileage would start to leak. BTW, it isn't the groove that's the problem....I always allow for that.
Edited by Diseazd
https://www.classiczcars.com/topic/47413-rear-seal/
  • 3 weeks later...
Just finished the tranny swap......while I was at it, I pulled the clutch and flywheel. The seal was dry, but I replaced it anyway. When I was finishing everything up, I noticed a drip of oil coming from the bottom of the heater hose. I lowered the car and discovered a pinched gasket at the rear of the valve cover........wasn't the seal after all.
https://www.classiczcars.com/topic/47413-rear-seal/#findComment-432716
  • Who's Online   2 Members, 0 Anonymous, 773 Guests (See full list)
