I'm just about ready to pull my head to change a head gasket.
How much does an E31 head, cam, and valves weigh?
After a day bending over the fenders pulling manifolds, my back is complaining. Just trying to figure out what I'm in for tomorrow. Is it a two man lift? :ermm:
https://www.classiczcars.com/topic/47503-how-much-does-an-e31-head-weigh/
Not really too bad. The hardest part is getting it broke loose to pull. One of my favorite tools is a 3lb dead blow hammer. Get her loose and use the cam as a handle to pull it off. Don't forget those 2 pesky bolts at the timing cover topside
My P79 head complete with head cover was recorded at 70 lbs.
You can do it on your own but make sure you protect very well the fender in case you have an issue during transfer. If you can have somebody helping you, it would be easier for sure but it is far from being impossible to do by yourself.
Ok, Got the head off and on the bench. Noticed that the oil galley hole feeding the head appears to have an orifice jet about 2mm in diameter. I assume this is correct and not a piece of junk blocking the oil feed.
With the three design variations in head gaskets and three different head bolt torque specs, Contacted FelPro for what the felt the specs were for their gasket. They came back with the factory spec.s of 33 ftlbs, followed by 47 ftlbs for my 12/70 car.
Have others had satisfactory performance at this low torque spec?
Head bolt torque is never related to gasket. It is always related to bolt specs.
I would get new head bolts, either from Nissan or from ARP. It's a cheap insurance for the future. ARP set is around $120. Stock units are probably cheaper.
If stock bolts are used, follow what's on FSM, if ARP's, follow their directions with their lube.
The part in the oil gallery is called the oil restrictor. You have a second one at the front of the engine, close to the front cover to feed the chain and the tensioner.
For your information, the restrictor between cyl #3 & #4 is the one we could increase to raise oil flow for the cam in racing or hightly tuned applications. I wouldn't mess with it, I'm just saying ;)
Edited by Lazeum
Double checked my 1970 Datsun Engine Manual and found the 32.5 and 47 ft-lb spec in three places.
Interestingly, immediately at the start of "Install the Cylinder head assembly." there is
"Note: a. Spread sealing agent over the cylinder block surface. Place gasket on it, and apply sealing agent to the gasket top."
There is a similar note for the gaskets of the timing chain cover.
I thought head gaskets were installed without sealant.
Spent the afternoon de-carbing the cylinder head. Pistons and block in the morning.
  • Who's Online   1 Member, 0 Anonymous, 1,445 Guests (See full list)
