Hey mates
This past afternoon I pulled the calipers off my front rotors to see why they were squeaking. As I had expected the pads are down to their last few mm and in need for a change - I also broke a metal brake line but that's for another day. I was going to purchase a set of Wagner Ceramic brake pads as replacement. Has anyone used these before? I have slotted/vented front rotors for reference, which need to be machined (and will be) before this is all said and done.
Thanks mates
Jan
https://www.classiczcars.com/topic/47533-brake-pads/
I'm curious about the Wagner Ceramics also. I went through a whole search for pads thing, using all internet info, and it came down to the Wagners or Centric Posi-Quiet Ceramic pads. I chose the Centric pads but haven't installed them yet.
I have Beck Arnley pads on now and they work well but they took some extra effort with the factory shims and anti-squeal spray to get them not to squeal. One pad still squeals when braking backward. One reason I went with Centric was that they seemed to have a good anti-squeal considerations,with shims pre-attached, and they say that they're "scorched" at the factory for minimum break-in time. Who knows...
https://www.classiczcars.com/topic/47533-brake-pads/#findComment-432785
Zed, I used the Centric pads on my car for the past three years (I don't drive so much really) and loved them but sadly they're pretty much gone now. I have a discount on the Wagner pads - $14 a set - which is why I ask. My driver's side pad (inner) is pretty much down to levels where I don't feel really safe driving much more then a few more days.
Jan
Edited by Pomorza
https://www.classiczcars.com/topic/47533-brake-pads/#findComment-432786
Porterfield R4S pads. You can get them through PMB Performance online cheapest.
I wish I had know that last week when I purchased a set of R4S pads online from the Porterfield website, the cost to my door in southern Ontario, $138. Half of that is UPS. I'm hoping they are worth it.
Chris
https://www.classiczcars.com/topic/47533-brake-pads/#findComment-432860
  • 1 month later...
Hey mates
Just wanted to update you all on the brake pads. I did indeed end up buying said wagner ceramic pads and from the first few rides I prefer these over the centric ones. They just seem a bit quieter and have a bit more stopping power, or at least it feels this way.
Thanks
Jan
https://www.classiczcars.com/topic/47533-brake-pads/#findComment-435510
  • 9 months later...
