I had a defective clip on my series I 240z. Ended up getting a single station fuse holder from Radio Shack. I carefully sectioned out the defective clip and squared the hole I made with a Dremel tool. Carefully cut the new fuse holder apart and fitted it into the newly made hole. Epoxied in the new clip and soldered in the lead. Hard to detect with the fuse cover on, but there if you look for it.
So yes it can be done, but it won't pass for a concourse restoration.
https://www.classiczcars.com/topic/47589-fuse-box-problem/#findComment-433092
