Rear bumper chrome assembly bolts? - Body & Paint - Classic Z Car Club Skip to content
Does anyone know the part number for the chrome carriage bolts that hold the rear bumper sections together?
Thanks JLP
I checked out my CD ROM micro fiche and this is what I found. Seems to be 3 parts to the assembly.
52663-18000 Bolt, Special
00915-51510 Washer, Plain
00911-11410 Washer, Luck
Hope that helps you out.
Mike.
Mike.
I am surprised that the nut was not listed. Mike my CD will no longer load leaving me at a disadvantage. I just want to make sure we are talking about the same bolt. It is the chrome bolt (4 needed in total 2 on each end section of the rear bumper) that hold the ends to the center section of the rear bumper prior to bolting the assembly to the car.
Jerry,
I believe that it is the correct bolt. It is the only one listed as "special" so I assume that that was related to the fact that they were chrome.
I was also surprised that a nut was not listed and in fact the diagram makes it look like the part labeled "Washer, Luck" should be a nut. Perhaps a bad translation.
Let me know if you need anything else. I'd be happy to try and help you out.
Mike.
Jerry,
One other thing. It does require 4 of each of the above part numbers according to my documentation.
Mike.
