front & rear strut bar for 280ZX can be used on 240z?
the rear strut bar for 280ZX can be used on 240z?
(I mean the bar inside the car)
what is the differences ?
the 3 holes for mounting suspension are equal to the 240z?
the distance between the two suspension is longer, shorter, equal?
for the front bar to be inserted above the engine of the 240z, I can use the scroll bar of the 280ZX?
what are the differences?
thanks
In the USA the 240Z (S30) and the 280Z (S30) have similar body styles, but the 280ZX (S130) is very different. For instance,the 280ZX does not use a MacPherson strut suspension in the rear, but the 240Z and 280Z do. So there is no need for a rear strut bar in a 280ZX.
The 240Z and the 280Z both use MacPherson struts in the rear, but the 280Z uses a longer vertical strut. So the distance between the two struts is different for the 240Z versus the 280Z.
The dimensions are shown in the illustrations in the Body chapter of the FSM's (see link below). You'll need to figure out what car you're working with, in Italy.
Index of /FSM
