Did anyone have a hard time fitting their turn signals on this air dam? The air dam's contours doesnt seem to fit the turn signals very well. Any tips or tricks that you did? Its on a 73 240z
Motorsport! Urethane Air Dam, With Brake Cooling Ducts, 70-8/74 240Z-260Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
I figured it out.. heres how..
1. Remove air dam from car
2. Install the turn signals, twisting the air dam as needed.
3. Apply heat from a heat gun (only to the turn signal area so the air dam would retain its shape) to soften the air dam material to release the tension from the turn signal light install.
4. Let cool to retain its new shape.
5. Install air dam on car
6. Enjoy :-)
Edited by dpascual1986
