Site Updates this Weekend ×
73 240z - yellow and green wire coming from the winshield washer wire bundle
Look below your brake master cylinder on the inner fender wall and spot a junction block for all the brake hydraulic lines. On top in the middle should be a electrical post - your wire goes there. As I recall, this is a low fluid/pressure sensor and will cause the e-brake light on your dash to light.
strong work bruu. it was exactly where you said it would be. thanks
It is possible that they are from a later ZX and in your'73 they are superfluous. On a ZX they hook up to warning sensors for low fluid.
Cheers' date=' Mike[/quote']
Long story short, cut them and make them disappear?
  • Who's Online   3 Members, 0 Anonymous, 728 Guests (See full list)
