So, I have a rear sway bar and a 1" front sway bar that I bought a long time ago. At the time "cornering like it was on rails" sounded like a good idea. Now that I am putting my car back together I wonder if there is much to be gained by doing this. The car will be a weekend driver and the odd trip to ZCON ( I hope). My days of spirited driving are long gone. Is this still a good idea or will it the suspension be too stiff to enjoy the ride?
https://www.classiczcars.com/topic/48042-1970-rear-sway-bar/
Each car is different. I like the sway bars all around but it totally depends on your springs, expectations, and condition of roads. Fortunately, they are relatively easy to add/subtract. I would try with, and if you feel too bumpy, try without. Definitely leave at least a front bar in though. You also have the option of using rubber bushings, or a harder bushing to slightly alter the ride and roll effect.
I find that shocks and springs, seat, then tires and rims affect ride comfort the most.
Roll bars only come into play in the corners. I find that when a car rolls it is unsettling as a driver. I find that if the car tracks flat around a corner, I have a better sense of the tires limit. I would not worry about the bigger roll bars except where they attach and the metal quality there.
  • 4 months later...
  • Who's Online   3 Members, 0 Anonymous, 826 Guests (See full list)
