AldaMax Posted December 6, 2013 Share #1 Posted December 6, 2013 Hi everyone,I'm actively looking for a Z in the LA area and I'm probably about to make a deal very soon.One of my main issue will be to keep my baby safe. I'm not a fool and I know that there is no 100% secured protection for a classic car but I'll do my best.Problem : I live in Venice and I'm moving into a new place with no parking spot and no garage (well, it's Venice). There is enough street parking though and the street isn't too sketchy, it's a relatively nice and safe area.What would you advice to secure the car ? I don't mind going through the hassle in the morning removing whatever security is 'on' as long as it works pretty well.I was thinking Club steering wheel lock, as a start, but what else ?Removing an important mechanical piece so the car won't start ? (which one and where is it located? I'm still learning)I'm also thinking of buying a car cover to protect it from UV and salty marine air. Maybe it's an additional theft protection or wouldn't they care at all ? (or worse, think the car is actually worth a lot more money...)Any advice welcome about keeping the car safe and protected in West LA (or other similar urban area I guess)Thanks! Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/ Share on other sites More sharing options...
Mikes Z car Posted December 6, 2013 Share #2 Posted December 6, 2013 I had removing the rotator cap work once. They ran the battery all the way down trying to start it but I got to keep the car. I have crazy ideas like a recording that makes the car sound like it is turning over when it isn't. Specifics might not want to be shared. There are immobilizers that come with alarms. New cars use immobilizers but the complicated electronics running the engine makes them hard to defeat. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437509 Share on other sites More sharing options...
SteveJ Posted December 6, 2013 Share #3 Posted December 6, 2013 On numerous occasions I have suggested removing the rotor. Thirty years ago, my family had to park our car in a hotel parking garage in SF. My brother pulled the rotor as an anti-theft measure. The car was always in the same place as we parked it. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437510 Share on other sites More sharing options...
Jarvo2 Posted December 6, 2013 Share #4 Posted December 6, 2013 Install an electric fuel pump and cutoff switch that only YOU know where it is! At the end of the day though, if someone wants your car they're going to pull it up onto a flatbed trailer & run off with it. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437515 Share on other sites More sharing options...
240260280z Posted December 6, 2013 Share #5 Posted December 6, 2013 I used to loosen the quick releases on my racing bike when going in a store.....maybe take the lug nuts off a wheel,,,, the car may go 10 feet before it drops like an anchor.A bike lock through a wheel can also jam a get away. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437517 Share on other sites More sharing options...
djwarner Posted December 6, 2013 Share #6 Posted December 6, 2013 A friend of mine had a normally open switch spliced into the starter wire going from the lock to the fire wall. He had the type of emergency brake where you pushed the pedal to engage and pull a knob to release. He set the switch so that you had to pull the brake release lever to close the switch and engage the starter.His thought was that most car thieves want to be gone in under a minute. Even if the perp pulled out the ignition lock, it wouldn't crank. After two or three twists with a screwdriver and no results, the perp would seek another vehicle to lift. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437521 Share on other sites More sharing options...
psdenno Posted December 7, 2013 Share #7 Posted December 7, 2013 I agree with those who mentioned pulling the rotor. I've done it for over 40 years. You can remove the coil to distributor wire instead. Either is quick, easy, and free.Dennis Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437526 Share on other sites More sharing options...
AldaMax Posted December 7, 2013 Author Share #8 Posted December 7, 2013 Awesome, thanks guys. Rotor it is then.What do you think about the steering wheel locks?I heard that for a real theft it's probably going to be a piece of cake to bend and remove it ? But additional protection is always good I guess, especially when it's very cheap ? Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437531 Share on other sites More sharing options...
240260280z Posted December 7, 2013 Share #9 Posted December 7, 2013 wire a second the coil to the seat Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437532 Share on other sites More sharing options...
zhead240 Posted December 7, 2013 Share #10 Posted December 7, 2013 I have a kill switch on the battery. I also kill the battery when in storage. it's easy to install and cheap. Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437533 Share on other sites More sharing options...
Bonzi Lon Posted December 7, 2013 Share #11 Posted December 7, 2013 For visual effect, leave an empty gun holster in the seat. (when the car is all buttoned up)Bonzi Lon Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437551 Share on other sites More sharing options...
GeoJoe Posted December 7, 2013 Share #12 Posted December 7, 2013 Car Zapper 9000 | NOBODY Messes With MY Car Link to comment https://www.classiczcars.com/topic/48102-keeping-my-z-safe-in-la/#findComment-437562 Share on other sites More sharing options...
