The only Z's that had Scarab emblems were the Factory built Scarab cars. There were less than 200 built by Scarab engineering between 1976-81. Of these only 17 are known to exist. I maintain the Scarab Registry. The Scarab emblems are simply not available as they were on these cars only. Unless you find a parted out factory car (if you do let me know) I'm afraid you're out of luck. Also, are you using a Scarab kit (or at least the motor mounts) ?.. most use the JTR equipment as they are readily available..
https://www.classiczcars.com/topic/48253-scarab-emblems/#findComment-438810
  • Who's Online   1 Member, 0 Anonymous, 1,442 Guests (See full list)
